Beiträge von s-master
jo eh keis problem!
ja eh da isch nice. grad mal ufem ovh vmware server usprobiere...
han jetzt dehte grad dä server wieder neuinstalliert und duenen jetzt wieder so vorbereite dass ich chan vmware server 2 installiere...
Han grad es geils Tool gfunde für Linux womer chan Hardware Informatione chan azeige inere Shell.
PHP
Alles anzeigenroot@XXX:/home# hwinfo --reallyall --short cpu: Quad-Core AMD Opteron(tm) Processor 2346 HE, 1800 MHz Quad-Core AMD Opteron(tm) Processor 2346 HE, 1800 MHz Quad-Core AMD Opteron(tm) Processor 2346 HE, 1800 MHz Quad-Core AMD Opteron(tm) Processor 2346 HE, 1800 MHz Quad-Core AMD Opteron(tm) Processor 2346 HE, 1800 MHz Quad-Core AMD Opteron(tm) Processor 2346 HE, 1800 MHz Quad-Core AMD Opteron(tm) Processor 2346 HE, 1800 MHz Quad-Core AMD Opteron(tm) Processor 2346 HE, 1800 MHz keyboard: AT Translated Set 2 keyboard graphics card: XGI Volari Z7 storage: nVidia MCP55 IDE nVidia MCP55 SATA Controller nVidia MCP55 SATA Controller nVidia MCP55 SATA Controller 3ware 7xxx/8xxx-series PATA/SATA-RAID network: eth0 nVidia MCP55 Ethernet eth1 nVidia MCP55 Ethernet network interface: lo Loopback network interface eth0 Ethernet network interface eth1 Ethernet network interface dummy0 Ethernet network interface tunl0 Network Interface gre0 Network Interface vmnet1 Ethernet network interface vmnet8 Ethernet network interface disk: /dev/sda 3ware Logical Disk 0 partition: /dev/sda1 Partition /dev/sda2 Partition /dev/sda3 Partition usb controller: nVidia MCP55 USB Controller nVidia MCP55 USB Controller bios: BIOS bridge: nVidia MCP55 LPC Bridge nVidia PCI bridge nVidia PCI bridge nVidia PCI bridge nVidia PCI bridge AMD Host bridge AMD Host bridge AMD Host bridge AMD Host bridge AMD Host bridge AMD Host bridge AMD Host bridge AMD Host bridge AMD Host bridge AMD Host bridge hub: Linux 2.6.18.6 ehci_hcd EHCI Host Controller Linux 2.6.18.6 ohci_hcd OHCI Host Controller memory: Main Memory unknown: FPU DMA controller PIC Timer Keyboard controller PS/2 Controller nVidia MCP55 Memory Controller nVidia MCP55 SMBus -
Habe gerade einen interessanten Artikel von VMware gelesen bezüglich Mobile Phones.
Die Herren von VMware wollen tatsächlich eine VMware Mobile Version herausbringen auf der man mehrere Betriebssysteme auf einem Handy laufen lassen kann.
Man stelle sich da nur die Möglichkeiten vor: Ich habe ein Nokia Handy mit Symbian Betriebssystem kann aber auf mein Windows Mobile auf meine Exchange-Kontakte zugreifen.
Nicht nur diese Kombination sollte möglich sein: Android auf Symbian. Symbian auf WinMobile und und und...
Das könnte in Zukunft sicher das Testen von mehreren Handy-Betriebssystemen erleichtern. Man hat ein Gerät und kann darauf gleich auf mehreren OS testen.http://www.neowin.net/news/mai…-with-2-operating-systems
http://www.electricpig.co.uk/2…obile-operatings-systems/
http://www.networkworld.com/ne…irtualization-on-the.html -
a running VMware Server 2 64bit on Debian 4 64bit with severals VMs Friday leeeeeet post
Machet mir btw. jetzt grad so um skv-clan.ch uf en neue Server z'zügle...
Jop d'Wiederherstellig uf en andere Server isch ebe immer so ä Sach. Wäge Triber etc.
Ich chans dir au nid 100% säge obs Funktioniert mit NTBACKUP SystemState mit AD und Exchange zum wiederherstelle. Willis leider au nie selber gmacht han mit eme AD und Exchange. Was sicher gaht isch en normale Member-Server z'wiederherstelle mitC:\ und SystemState. Das gaht ohni Problem.
Mit andere Tools chan ich dir aber en Weg beschriebe wo 100% funktioniert. Jedoch isch d'Frag ob dir das so öppis bringt.
Kurz-Beschrieb
Du sicherisch dini Maschine mit em Acronis True Image Server
Nimmsch das Backup und erstellsch en Virtuelle Klon vo dim Server
Lasch dä Virtuell Klon uf eme VMware Server laufe.
Din Server isch wieder ONLINE und dini Mitarbeiter chönd wieder normal schaffe.
Dä hacke a därä Sach isch nur das es halt ä Übergangslösig isch das mer eifach wieder ufem Server chan druf schaffe.
Idärä Ziit chasch du aber dir Ziit näh zum dä Richtig Server wieder in Ornig bringe und machsch hachher wieder en Wechsel sobald dä wieder lauftHow to get this work ?
Installation von Acronis True Image Echo Server 9.5. Eine Test Version gibt es bei google--> acronis. Dazu muss aber ein Account erstellt werden bei Acronis damit man eine 30-tägige Serial bekommt.
Der Server muss nach der Installation neugestartet werden.
Nach dem Reboot True Image Server starten und ein neues Backup der Partition C:\ und weiteren gewünschten Partitionen erstellen.
Wie im Detail ein Backup erstellt wird ist ein kinderspiel und wird nicht weitere hier erwähnt.
Nachdem das Backup erfolgreich erstellt wurde ladet man folgende Dinge bei VMware.de herunter:
VMware vCenter Converter Standalone Client
VMware Server 2 oder VMware Server 1.Die beiden Tools installieren und Server rebooten.
VMware vCenter Converter starten. Mit diesem Tool lässt sich das tib-Backup File von Acronis als virtulle VMware Maschine convertieren (pysical to virtual)
Auf Convert Maschine klicken und das gewünschte Backup-File auswählen. Wer sich mit VMware Server auskennt der wird wissen was er für notwendige Einstellungen gemacht werden müssen. Sonst reichen auch die Default Einstellungen für den Anfang. Da es später eh noch möglich ist die Konfiguration der VMware Maschine zu ändern.
Das konvertieren braucht seine Zeit und der Status im vCenter Converter stimmt am Anfang nicht immer. Bei einer 10GB System Partition dauerte der Vorgang 20 Minuten.
Wurde das Backup erfolgreich konvertiert kann jetzt die erstelle VM-Maschine auf den VMware Server geladen werden und starten. Anschliessend sollte in der VM die VMware Tools installiert werden damit der Server optimal arbeiten kann.
Nach einem Reboot kann der Server überprüft werden ob alles wieder so läuft wie es sollte. Ist dies der Fall hat man sein Ziel erreicht
Datenfestplatte partitionieren und formatieren
cfdisk starten
Eine neue Partition für die sda3 Festplatte erstellen.
Festplatte formatieren
mkfs.ext3 /dev/sda3Dieser Vorgang dauer recht lange. ca 30 min bei 700GB
sda3 Festplatte als home-Verzeichnis mounten
mount /dev/sda3 /homeMit df -h überprüfen ob das Laufwerk richtig gemountet ist und die richtige Grösse hat:
Ins source verzeichnis wechseln
Kernel Version 2.6.27.10 herunterladen.
Tools für die Kompillierung herunterladen:
Pakete herunterladen:
PHPapt-get install gcc build-essential libx11-dev libxtst6 libx11-6 psmisc xspecs libice6 libsm6 libxt6 libxrender1 x-window-system-core x-window-system(Wichtig ist das die Linux-Headers Files installiert werden X-Window wird ebenfalls installiert. Ob dies wirklich notwendig ist bin ich mir nicht ganz sicher. Es gibt zwar Anleitungen mit denen es ohne gemacht wird)
Pakete updaten und upgraden
Kernel-Archiv im aktuellen Verzeichnis entpacken
SymLink anlegen
ins Kernel Verzeichnis wechseln
OVH Config herunterladen
OVH Config als neue Datei anlegen
String ersetzen CONFIG_LOCALVERSION="-nopatch-xxxx-ipv4-32" --> CONFIG_LOCALVERSION=""
Grafische Config Oberfläche starten
Loadable Modules aktivieren, Prozessor auf Xeon stellen, tickrate auf 100hz, IPv6 Enable, KVM Linux Virtualisazion disable (disable not the hardware support) den Rest auf Standard belassen
menuconfig beenden und speichern.Kernel kompillieren
Bootloader anpassen: image=/boot/vmlinuz-2.6.xx --> image=/boot/vmlinuz-2.6.27.10
Bootloader neustarten
Wenn alles ohne Fehler durchgelaufen ist Server neustarten mit reboot
Nach dem Reboot ins Verzeichnis /home wechseln und mit wget http://skv-clan.ch/temp/VMware….0.1-156745.x86_64.tar.gz herunterladenArchiv entpacken
Ins VMware Server 2 Verzeichnis wechseln und vmware-install.pl ausführen
Der Installationswizard wird gestartet. Diesen mit den Defaultwerten durchspielen.Wichtig ist vor allem dieser Punkt der Installation:
ZitatAlles anzeigen
None of the pre-built vmmon modules for VMware Server is suitable for your
running kernel. Do you want this program to try to build the vmmon module for
your system (you need to have a C compiler installed on your system)? [yes]Using compiler "/usr/bin/gcc". Use environment variable CC to override.
What is the location of the directory of C header files that match your running
kernel? [/lib/modules/2.6.27.10/build/include]Da es keine passende Binaries für Debian 5 gibt müssen diese selber kompilliert werden. Dazu benötigt man die Header-Files des entsprechenden Kernels.
Ports evtl. auf andere anpassen.
Please specify a port for remote connections to use [902]
Please specify a port for standard http connections to use [8222]
Please specify a port for secure http (https) connections to use [8333]Definiert das Verzeichnis wo die Virtuellen Maschinen gespeichert werden sollen
VMware Administrator bestimmen. Falls es nur den Benutzer root gibt unbedingt diesen angeben da man sonst gar kein Zugriff hat.
Die Serial Nr. muss auch einmal eingegeben werden. Diese ist für einen Linux VMware Server : XXXWenn die Services erfolgreich gestartet werden konnten wurde VMware Server 2 erfolgreich installiert:
ZitatAlles anzeigen
Enjoy,--the VMware team
Starting VMware services:
Virtual machine monitor done
Virtual machine communication interface done
VM communication interface socket family: done
Virtual ethernet done
Bridged networking on /dev/vmnet0 done
Host-only networking on /dev/vmnet1 (background) done
DHCP server on /dev/vmnet1 done
Host-only networking on /dev/vmnet8 (background) done
DHCP server on /dev/vmnet8 done
NAT service on /dev/vmnet8 done
VMware Server Authentication Daemon (background) done
Shared Memory Available done
Starting VMware management services:
VMware Server Host Agent (background) done
VMware Virtual Infrastructure Web Access
Starting VMware autostart virtual machines:
Virtual machines doneThe configuration of VMware Server 2.0.1 build-156745 for Linux for this
running kernel completed successfully.Nun können Virtuelle Maschinen über https://ip-oder-domain:8333/ hinzugefügt und gestartet werden.
Falls folgender Fehler beim Starten einer VMware Maschine auftaucht in den Event-Messages:
Failed to initialize monitor device.
The virtualization capability of your processor is already in use. Disable any other running hypervisors beforce running VMware Server.
Dann wurde die KVM Linux Virtualisierung beim Kernel kompillieren mitinstalliert.
To Do's: VMware Server 2 deinstallieren. Kernel neukompillieren. VMware Server installierenWorks Fine NOW!
cat myfile
Zeigt inhalt einer Datei in der Shell anvi myfile
Startet Konsolen basierten Text-Editor (schwer)nano myfile
Startet Konsolen basierten Text-Editor (einfach)cfdisk
Startet Parititionierungsmanagermount /dev/hda2 /home
Mountet die Festplatte hda2 unter /homeumount /home
Entmountet /home wiederwget http://myfile
Lädt eine Datei über das http/ftp Protokoll heruntertar xfvz mytarfile.tar.gz
Entpackt alle Dateien des tar-archivsapt-get install myPackage
Installiert das angegebene Paketdpkg -i myDebianPackage.deb
Installiert das angegebene .deb-Paketar -xf myDebianPackage.deb
Entpackt alle Dateien eines deb-Paket../myShellScript.sh
Führt ein angegebenes Script oder ausführbare Datei aus -
mit eme wurmloch gaht da scho. Da chach es .worm File erstelle wo 0 Byte gross isch dehte isch dänn alles drin gspeichert. Nice oder ?
Musch halt google wägem Tool heisst glaub WormZapper oder so
jetzt ernsthaft: wännt nur dä systemstate sicherisch sind d'files vom Laufwerk C:\ nid däbi. also isch dä au viel chliner vo dä filegrössi her
atm. down
ich bin unschuldig
HTTP/1.1 404 Connection: close Date: Wed, 18 Feb 2009 16:36:24 GMT Server: Microsoft-IIS/6.0 X-Powered-By: ASP.NET MicrosoftSharePointTeamServices: 12.0.0.6334
gseht so us als obs en Französische Server händ: Impossible de se connecter à la base de données. Vérifiez les informations de connexion à la base de données et assurez-vous que le serveur de base de données fonctionne.
Admin vo Parlament.ch söll pls das lese: http://www.parlament.ch/_layou…=1031&Key=troubleshooting
Wers bi eus ghostet het das nöd chöne passiere!!
guet blc
hät au es netts Favicon
1337 are you Chräbi enough ?
Sechs Jahre nach dem letzten Facelifting präsentiert sich die Website des Parlaments http://www.parlament.ch ab dem 18. Februar 2009 in neuer, zeitgerechter und zugänglicher Form.
Mit dieser Neuprogrammierung und Neugestaltung einer der meistgenutzten Website der öffentlichen Hand werden in erster Linie folgende Verbesserungen erreicht:
1.Logische und konsistente Sitestruktur mit verständlicher Benutzerführung
2.Zeitgemässes, benutzerfreundliches und konsistentes Design
3.Verbesserung der Zugänglichkeit für behinderte Personen gemäss den Richtlinien des Bundes sowie den Empfehlungen des W3C World Wide Web ConsortiumsDer Umfang des inhaltlichen Angebots bleibt unverändert.
my first leet post in this year
and friday the 13th leet
da chan ich dir guet däbi helfe...
also du wotsch dä ganz Server backupe mit NTBACKUP und du wotsch dir sicher si, dass dä Exchange und AD no laufet bime restore... ?
NTBACKUP
Wichtig isch das alles usgwählt häsch wo du wotsch backupe. Alli Drives und Wichtig fürs Active Directory isch dä System State und für dä Exchange Server alli Speicherpostfächer.Siehe Screenshot
Aber...du seisch du wotsch d'E-Mails ufem NAS speichere ? Also d'E-Mails sind atm. lokal uf dim Exchange, isch da richtig ? Und du weisch nöd wo d'Mails bzw. d'Exchange Datebank abgspeicheret isch ? d'Datebank isch Standardmässig unter C:\Programme\Exchsrvr\MDBDATA gspeicheret. I däm Verzeichnis findsch du paar grossi edb-Files und schuscht söttet no logs und stm-files drin si. Im edb-file sind alli Postfächer drin gspeichert.
Falls d'Datebank nid unter däm Pfad findsch muesch go nah luege wo die gspeichert isch:S'ganze Backup-File wo dä NTBACKUP erstellt wotsch nachher im NAS ha ?
Nachdem bei Brack endlich vermehrt Solid State Disks verfügbar waren konnte ich es nicht sein lassen mir eine solche zu bestellen.
Gesagt getan und nach einigen Tagen hatte ich die Disk am Arbeitsplatz geliefert bekommen. Ausgepackt und gleich ein Clone meiner vorhanden Fujitsu 120GB SATA 2.5" Festplatte auf die neue OCZ SSD 120GB gemacht.
Anschliessend normal weitergearbeitet... viele Tools geöffnet etc. und dann ein Benchmark gemacht.
Bevor ich den Benchmark durchgeführt hatte öffnete ich zur Erinnerung folgender Screenshot eines Lese-Benchmarks im HD Tune von der normalen SATA 2.5" Festplatte.
naja nicht gerade berrauschende Werte. Durchschnittliche 41MB pro Sekunde und 17.1ms Zugriffszeit.
Dafür sieht es mit der Solid State Disk um einiges Besser aus:
Sagenhafte 109MB / sec im Schnitt und eine Zugriffs Zeit von 0.2 ms!
Und hier noch ein Screen meines Desktops auf dem die File Lese und Schreibgeschwindigkeit getestet wird.
Ein Fazit möchte ich noch nicht ziehen da ich noch nicht alles getestet habe was ich gerne noch vorhabe:
Ein Vergleich der SSD mit der SATA 2.5"
- Boot Geschwindigkeit
- Starten von Applikationen wie Photoshop, Notes, Office
- Test mit einem frischen System
- Ein Bench im Stile von ocaholic.ch
- Auf einem nicht Notebook System z.B. Desktop GamePC
- im RAID -
Es wurde ein kleines Tool geschrieben welches den Speicherplatzbedarf einer SharePoint 2007 Datenbank mit dazugehörigem Index berechnet. Dazu kann einfach die Anzahl Versionen die pro Dokument geführt werden, die Anzahl Dokumente pro Tag und die durchschnittliche Dokumentgrösse eingegeben werden. Anschliessend können die Ausgabeeinheiten ausgewählt werden und zum Schluss kann die Berechnung gestartet werden.
Was ist Silverlight 2?
Silverlight ist Microsofts Implementierung eines Browsers- und Plattformunabhängigen Client-Framework, welches Designern und Entwickler erlaubt Rich Internet Applikationen zu entwickeln. Silverlight Applikationen laufen Clientseitig auf einem beliebigen Browser wie Firefox, Internet Explorer oder Safari. Durch die Integration des .NET Frameworks können Entwickler sehr einfach auf bestehende Code-Libraries zugreifen und deren Funktionalitäten in Silverlight Applikationen nachnutzen. Silverlight kann als Kombination von drei verschiedenen Architekturen angesehen werden:
- Das Browser Plug-In
- Das Presentation Framework (Teil von WPF)
- Das .NET Framework
Das Silverlight Presentation Framework ist ein Teil vom Window Presentation Foundation (WPF) was auf der XAML Programmiersprache basiert. XAML basiert auf XML und ist daher sehr einfach zu erlernen. Alle UI Elemente von Silverlight sind vektorbasierend und erlauben es einfaches und dynamisches anpassen von Grösse und Form ohne Qualitätsverluste. Die WPF Implementierung in Silverlight bietet eine Vielzahl von Controls wie Buttons, Kalender, Textboxen, Scroll Viewers, DataGrid und vieles mehr. Die Silverlight Media Pipeline ermöglicht es ausserdem auf einfache Weise das Streamen von WMV, MP3 und JPEG Dateien. Silverlight Applikationen laufen wie Adobe Flash als eingebettetes Objekt auf einer Webseite im Browser. Wenn der Benutzer eine Webseite mit einer Silverlight Applikation aufruft lädt der Browser ein XAP Package vom Webserver herunter. Dieses XAP-File beinhaltet Binaries und Ressourcen um die Silverlight Applikation im Browser laufen zu lassen.
Warum Silverlight Applikationen erstellen?
- Der grösste Vorteil von Silverlight ist die nahtlose Integration von XAML als deklarative Sprache mit dem .NET Framework.
- Die strikte Trennung von UI (XAML) und Programmlogik (.NET managed code) erlaubt es Designer und Entwicklern effizienteres Arbeiten mit dem Expression Blend und Visual Studio
- Es ist eine Cross-Browser und Cross-Plattform Technologie
- Das Silverlight Plug-In ist in Sekunden installiert und ist sofort im Browser lauffähig.
- Silverlight als Clientseitige Applikation ermöglicht er Daten zu lesen und updaten ohne die ganze Webseite neu laden zu müssen.
- Darstellung von hochauflösenden Videos, Musik und Grafiken
- Webseiten können komplett in Silverlight designed werden und sehen Pixelgenau gleich aus auf verschiedenen Browsern die das Silverlight Plug-In unterstützen
Was braucht es zum Silverlight 2 Applikationen zu entwickeln?
- Visual Studio 2008 SP1 oder Visual Web Developer Express SP1 (Entwicklungsumgebung)
- Microsoft Expression Blend 2 SP1 (UI Designer)
- Optional: Deep Zoom Composer (Erlaubt es Bilder für das Deep Zoom Feature vorzubereiten)
- Optional: Silverlight Toolkit (Das Toolkit beinhaltet weitere Silverlight Controls: http://www.codeplex.com/silverlight)
Die Silverlight Tools für Visual Studio 2008 SP1 (http://go.microsoft.com/fwlink/?LinkId=129043) beinhalten folgendes:- Silverlight 2 developer runtime
- Silverlight 2 software development kit
- KB956453 für Visual Studio 2008 SP1
- Silverlight Tools für Visual Studio 2008 SP1
- VB und C# Projekt-Templates
- Intellisense und Code generators für XAML
- XAML design Vorschau
- Debuggen von Silverlight Applikationen
- Remote Debugging von Silverlight Applikationen für Mac
- WCF Templates
- Team Build und Kommandozeilen Build Support
- Integration mit Expression Blend
Quelle: Wiley's Silverlight 2 Bible originally written on http://sharepoint.namics.com/2…7_storage_calculator.html
No en interessante Blogitrag vom Fredy Künzler über FTTH: http://www.blogg.ch/index.php?…TH-Fibre-to-the-home.html
Bern - Nachdem die Glasfasern in die Quartiere und zu den grossen Unternehmen gezogen worden sind, erfolgt nun mit innerhalb der Aktion "Fibre Suisse" die Erschliessung der Privatkunden und kleinen und mittleren Unternehmen.
ZitatAlles anzeigenGestartet in Zürich, Basel und Genf werden bis Ende 2009 bereits 100 000 Wohnungen mit Glasfaser erschlossen sein. Das berichtet die führende Schweizer Kommunikationsanbieterin Swisscom AG in einer Pressemitteilung. Gemäss Planung soll der Ausbau im Laufe des kommenden Jahres für Wohneinheiten auf die Städte St. Gallen, Bern, Fribourg sowie Lausanne ausgeweitet werden.
Die ersten Angebote für Privatkunden und kleinen und mittleren Unternehmen werden Angaben der Swisscom zufolge im ersten Halbjahr 2009 lanciert. Swisscom plant in den kommenden sechs Jahren insgesamt rund acht Milliarden Schweizer Franken in die Schweizer Telekom- und IT Infrastruktur zu investieren, davon entfallen rund 35 Prozent auf den Glasfaserausbau.
Die Swisscom baut bereits seit 150 Jahren Telekommunikationsnetze. "Um die Spitzenposition in der Breitband-Kommunikation auch in Zukunft zu halten, baut Swisscom seit Oktober 2008 ihr Glasfasernetz bis zu den Privatkunden und kleinen und mittleren Unternehmen aus.
Die bestehende Infrastruktur hilft bei diesem Aufbau, denn durch die Investitionen in das Glasfaser-betriebene Basisnetz (Backbone) sowie den Ausbau von Glasfasern bis in die Wohnquartiere für die Verbreitung von VDSL verfügt Swisscom bereits heute über ein dichtes Hochleistungsnetz", garantiert das Unternehmen.
Begründet wird der Ausbau des Glasfasernetzes mit dem Bedürfnis nach neuen Geschäftsanwendungen wie zum Beispiel Voice over IP (VoIP), Unified Communications und Videokonferenzen, die höhere Netzkapazitäten erforderten.
Die Swisscom will in einer Kooperation mit der Telekom-, Kabel- und Elektrizitätsbranche das Glasfasernetz gemeinsam zu bauen. Ziel dieser Kooperationen sei es, das Glasfasernetz mit mehreren Partnern schneller und auch kostengünstiger zu errichten, so das Telekommunikationsunternehmen. Zudem lasse sich durch die Zusammenarbeit ein Wettbewerb der verschiedenen Netze erwirken, der Investitionen und Innovationen fördere und den Kunden und Hauseigentümern die grössten Vorteile biete.
Damit mögliche Kooperationspartner auch nach Baubeginn ihre eigene Glasfaserinfrastruktur erweitern können, verlegt Swisscom in allen Gebieten mehrere Fasern pro Wohnung, so das Unternehmen. Eine Faser will Swisscom selbst nutzen. Die weiteren Fasern stünden Kooperationspartnern zur Verfügung. Mit dem Mehr-Fasern-Modell lasse sich verhindern, dass in der Schweiz ein neues Netz-Monopol geschaffen werde.
In der Pilotphase, die Anfang März starten und im Herbst 2009 in ein kommerzielles Angebot übergehen, soll sich das Angebot auf die bereits mit Glasfaser erschlossenen Gebiete in Zürich, Basel und Genf konzentrieren.
Mit dem Glasfaserausbau wird zunächst die Infrastruktur bereitgestellt, die für zukünftige Produkte und Angebote für Privatkunden sowie kleine und mittlere Unternehmen notwendig ist. Erste Angebote werden voraussichtlich im ersten Halbjahr 2009 auf den Markt kommen, verspricht die Swisscom.
Quelle: digitalfernsehen.de
1337
